- Jun 8, 2016
- 655
They come in all kinds of configurations. Most of the systems run off typical shop compressed air. If you look at that thread I referred you to, I showed some links to misters that cost about 10 bucks. I run mine at 40-50 PSI and the air-flow is so low, I'd say I have leaks in other fittings in the system that waste more air than my mister does. FWIW, I use Kool-Mist branded solution. Comes in 8 oz bottles. Mix 1 cap to a quart of water. A quart last me several days to a week of heavy lathe use.
These are my personal thoughts/opinions/practices. Your mileage may vary and I highly encourage you to experiment. Like I said, the only thing I really encourage is that you stop using oil lest you damage your health.
Regards
Ray C.
Any limitations on what material you can use the coolant on? I have seen some soluble mixes that are meant for specific materials, or some have said not for titanium. Just wondering if it will work on everything, or if you have to have other formulas if you change materials.
