- Mar 19, 2014
- 2,682
Your creativity is admirable but I guess I’m going to be the sour note here. Ball/roller bearings need more real estate than your lathe headstock has got. And I’m guessing the lathe does not have any high RPM’s on its speed chart. Back then a typical bearing material was Babbitt. It was heated to molten and poured into place and then scraped to fit, finish, alignment and all of that (an art in itself!). Unless you do some radical modifying to the headstock and probably change the spindle, all for bearings. I would go with what it had originally. If done correctly, it should last a lifetime. Good Luck in your restoration.
