- Sep 18, 2014
- 5
I have a very old lathe that I'm wanting to convert to bearings. The lathe is an old 1890s pedal lathe, converted to motor by my wife's grandfather, about 40 years ago. I've restored it with a complete tear-down, de-rust, and rebuild, and I've used it for a little bit of woodwork and metalwork. The headstock shaft runs in oiled slides, and I'm wanting to put some bearings into the headstock shaft, for several reasons...
1) Oil makes a big mess of the headstock, dribbling everywhere, and sawdust sticks to the oil when I'm turning wood. It also can spray oil up the wall and up my arm when I turn it on.
2) It has oil feeds added to it, but these drip through, such that if I don't use it for a few weeks (quite common), the oil is empty next time I want to use it - which means I have to remember to put oil in it most times I use it.
3) And most importantly, if I am turning between centres, and put much pressure with the tailstock, the mechanism binds up to the point where the drive belt slips. This greatly limits turning between centres - with the minimal pressure applied at the tailstock, I often find that the bearing tailstock is not even turning, because the tailstock couldn't be turned up tight, and slips back loose during turning.
4) If I re-machined the radial load area of the shaft, and found a really good suitable machine oil from somewhere, most of these issues would probably improve, but bearings would just be so much nicer.
Having pulled apart the gears in the rebuild, I'm happy to do it again, and I have done so in the picture above (some pieces are missing, so you can see the important bits), and I'm trying to figure out how to add a bearing setup to this.
On the right hand end, the original setup has a sleeve that fits in two halves around the shaft, and is oiled. I'm having trouble working out how to fit bearings into this, as there is a large flange on the end of the shaft. I was originally thinking about turning this off, before realising that the chucks seat back against this flange! So, I can't take that off. At the other side of the bearing is the big gear, which looks like it might not be a single part with the shaft, but there are no screws or anything else fitting the gear to the shaft, so I can't get it off.
Anyone got any ideas how I can fit a bearing onto this shaft? Any secret tricks to removing and refitting the gear on the shaft?
At the other end, the pulley wheels and back gear mechanism take up almost all the space to the left end, leaving almost no room for a bearing at that end, but perhaps I can fit a smaller bearing inside the tail end, to just take the radial load of the drive pulley. Originally the tail end took all the axial load from the shaft, but I'm thinking if I put a tapered bearing into the right hand end, then the left end can be smaller and simpler.
I'm happy to explain more details and give measurements, photos, etc, but I wanted to start with the overall picture and see if there are any ideas/interest out there, or whether people will slap me a say "Stop that!". Any thoughts?
