I recently migrated my 7x10 HF mini lathe to a 16" bed using the LMS kit. Everything is running smoothly, including the Z-axis DRO scale which had to be lengthened.
The last step is to check for bed twist-induced taper and correct it, if needed.
I have a 24" long piece of 13/16" diameter aluminum round bar for testing, there's about 14" between the ER32 spindle collet chuck face and a live center point in the tailstock.
Is their wisdom in measuring cut taper over the full 14" or, is a smaller distance, say 7", sufficient to establish taper?
Thanks.
Thanks.
