- Nov 25, 2013
- 19
so - if "it is easy to overshot the mark" what happens when the carriage does hit the stop and try to keep moving - does it damage the nut, disengage somehow or what?
Thanks in advance :thinking:
You have to disengage the half-nut from the lead screw BEFORE the carriage hits the stop (or bad things happen). Then you can manually feed the last bit by hand until you contact the stop. That way every cut ends in exactly the same spot.
