Paddy,
Wow, I very much appreciate your time and effort to provide such helpful information. The Front Page sentence that reads, "If you are tired of the drama, nastiness and elitism on other machinist sites, you have reached the right place"! is really true.
You wrote that a boring bar is the preferred method for a straight, true hole. If the reamer follows a drilled hole that runs out, the reamer can't fix it. Where might a reamer be used or be superior to the boring bar? Small holes that a boring bar can not reach into?
You asked what tool post style & size does my machine have. I use the Phase II AXA size QCTP. The boring bar tool holder has a bore of .75" with a sleeve that can hold a .625" bar. This is it here. http://www.littlemachineshop.com/products/product_view.php?ProductID=2283&category=
You said the HSS bits are always made to be removed, resharpened and replaced. I think this is where I am way of base. Consider this image from Borite.
http://www.boritemanufacturing.com/hi-speed_tools
Those look to me like solid ONE piece bars. That is, once the cutting edge is worn down and resharpened enough, it is at the end of its useful life. I don't see anything that can removed, resharpened, and replaced. Maybe it is the image that fails to show me how this works.
What is the proper name of the boring bar with the removable bit and set screw?
It would appear that a boring bar with indexable HSS insert would work well for my machine. I am not sure that exists. That would be a tiny piece to hold and sharpen.
Thank you.
Phil
Thank you.
Phil
