You are going to find that buying a mill is a lot more complex than buying a lathe and your choice is very much dependent on what it needs to do. Take a hard look at what your work envelope is and choose a machine that will give you the capacity, precision, rigidity and power you need.
Sherline mills are small, light weight machines. They are every bit as precise as their lathes and can do everything a bigger mill can do, just on a smaller scale. With the right accessories, a Sherline mill can do a surprising array of complex projects. The key attraction of this company's line is their cost. You can fully tool a Sherline mill for far less than most mills, and the work you can accomplish is limited only in size.
With that said, if you may need to go bigger someday, now is the time to go bigger. I also own an RF-31, a 400# machine that is considered a smaller benchtop machine. The rigidity, power and size capability is significantly better but it is not more precise than a Sherline mill. The tooling costs have been on the high side because of the kind of tools I've chosen to buy but the cost is significantly higher as you go up in size. I got the RF-31 for free and it cost less than $200.00 to get it running like new, with less than 0.0001" TIR at the spindle so it worked out. However, if I were to buy a mill today for my little shop, I would buy a PM 835S; still might one day.
Bottom line: look at the work envelope you need, space and budget. Keep in mind that it is very likely that the tooling costs will surpass the cost of the mill when you're fully tooled up.
