- Sep 4, 2017
- 7
Thanks for all the info again. Good news is it's the long bed mk1 with the 2 speed motor (must be after reading about them) as the speeds look like they range from 36-1600 rpm. I'm hoping to go with carbide to start as I'm not currently setup to grind tools and am hoping I can narrow down what will already be a steep learning curve I'm sure.
I'm reading up on the change gears as it seems like it's set up with a gearbox for imperial, but I guess swapping out change gears gives more range on avail threads? This one seems like it's setup imperial but I've read of a condor gearbox that would do metric with this particular lathe. Hopefully it's just a case of needing some different gears if I wanted it to do imperial.
