That has chatter written all over it.
I've used the rotary table to machine some big radius, had to cut down this 24 inch sheave. Worked well, nice finish even. The DC gear motor was salvage from a blue print machine. This is an 8 inch rotary table.
At minimum, it will sing unbearably. Next most likely is spin the shank in the collet. If R8 shank, possibly shear the key.
Lock the quill and feed with the knee. If neither fit nor finish are important, you MIGHT get away with it. Otherwise, the likelihood of desirable outcome is very low.
I just trepanned an 8 in. circle on a BP clone.
It was agonizingly slow, chattered like crazy and the tool grabbed frequently, stalling the mill or spinning in the collet.
YMMV
Thanks. I am leaning away from using this setup and trying the rotary table option instead. I'll need to make an adapter plate, but that's not a big deal. It just doesn't feel good to me.
Well, I decided it was already set up, so I'd try to carefully see how a skim cut went. It went surprisingly well. I remembered that the mill has reverse on the power feed, so I used that to run it. I took 0.025" off the diameter in 3 passes. VFD turned down to 40hz.
Thanks! I'm still a little surprised at how well it went. I would prefer not to have that much tool stick out ever again.
Stupid cast iron dust. I remembered why I didn't want to work on more of it once I was cleaning up the mill table. Thankfully I remembered to cover the ways. Cleaned and lubed everything, trammed the head. I think it's ready for the next project. And I don't have to bend over to reach the controls now.
