I got a spacer for it. It fits great on the column, but the turret is a few thou too big. I was thinking of clamping it to the table and boring it out a little. I figured I should ask here in case I might have missed something and to get tips for the setup. I tried lining it up with the long bolts it came with and getting it as straight as possible. No dice. It's not off much, but I don't have a caliper or mic big enough to measure it properly. It's close enough I suspect I could pull it in with the bolts, but I would rather not have it press fit on there.
So I thought I'd clamp it down, or if it will fit, use the vise. Then use the Criterion boring head with a bar in the side mount. That would have a little over 6" from the spindle. Seems like a fair bit of stick out, but it is a light cut.
Another option is to use a rotary table. Mine is pretty small, 6" I believe. So I could mount a plate to it, clamp the spacer to the plate, and use a normal milling cutter on the ID.
My lathe is a PM1127, so I can't chuck it up on there..
