That makes much more sense. Thanks!
Yes, totally new to all this, and the language of the two is my first hurtle.
Another small step I should be working on?
I can handle that tomorrow.Pin 2 (signal input) is where you will connect the Kanalog JP11, DAC_10V for each axis. DAC means Digital to Analog Converter, and in this case +/- 10 Volt output
Pin 4 (signal common) is where you will connect the Kanalog JP11, GND
