Knurling with Hand Tools
Anyone have experience knurling w hand tools? Any issues or things to keep in mind with the different tool styles ?
Occaisionally I have small pins (1/8 to 3/16") that need knurling on the end. The hand tools appear to be an easy fix, if they work as advertised.
[Edit: Sorry, I read further down the thread and see that you already found this one; at least you now know a little more info and that it will do drill rod – Charlie]
I picked this up a few years ago on eBay from the guy that made it (see previous post/thread):
Worked well on 3/8" drill rod:
Advertised to work down to 1/4" and it might do 3/16", but not 1/8". It weights 3+ lbs., is a little awkward on small diameter rod and can't get too close to the end (it works not unlike a pipe cutter: crank the handle, roll around the rod, crank/roll & repeat). However, it may give you some ideas.
Just checked and the guy is still making these, and has a smaller version that will go down to 3/16". You can try reaching out to him and see if it would do 1/8" (or if he'll make you one that will):
Straight knurling wheels, but you can get diamond ones.
Good luck!
Good luck!
ChazzC,
Thanks for the report. It knurled that steel well. My smaller rod is actually a shade less than 1/8" so I'll see if he can work w that.
Joe
Works on c1215 steel. That is not very hard.
I had another thought. Maybe you could adapt a tube cutter
Jimsehr, that's a great idea; converting a tube cutter into a knurler. Looking at my tube cutter, the blade is readily replacable, but there's only about 1/16" room, lengthwise, to fit a knurler wheel. How long are the wheels in your unit?
Ok, thanks for investigating. I'll buy a knurler wheel online and try it out.
It's hard to believe the c-clamp style cutter would provide the pressure to imprint steel, but we'll see.
I've got a Rockwin hand knurler like the photo below. Works great on aluminum and CRS. Mine is set up with straight knurls.
Bruce
Jimsehr's idea of using a copper pipe cutter, and replacing the cutting wheel w a knurler wheel, worked!
Most knurling wheels were too wide, but on Ebay I found one that was 3/16" wide, just a little more than the pipe cutter gap. I opened the pipe cutter gap w a fluted steel cutter on a dremel, and also dressed the opening w a coarse file. Worked very well. Note that the dremel's grinding stone was too slow in removing material, but the HSS cutter was very fast. I was surprised that the little pipe cutter had the force to impress the tool steel pin, but it worked well.
Looks good. If you replace the two rollers with opposite direction knurls you should be able to get full diamonds.
