I just saw the only standard thread pitch listed on KBC site for this lathe is 28tpi. Plus all the metric ones.Huh???
Absolutely not! Lathes need to cut a whole bunch of threads, both English and metric, to be useful in a hobby shop. Something would have to be jammed or broken or missing to only be able to cut one thread pitch. The lathe is worthless without a useful collection of thread pitches, easily changed as needed. Some smaller and cheaper and older lathes require manually changing gears in a train between spindle drive gears and carriage driven gears for each different thread pitch, which works just fine, just takes longer to setup for a different thread pitch.
my police car in the driveway buys me lots of leniency. Its a trade off.Hey Skim, you better get those inside quick, before the HOA sees them.
I believe these are but i have not looked at any of the machines gearing yet. I just took them out of the ultrasonic cleaner.That looks a lot like my Enco GH-1340a
They are pretty good tools.
Internally they are like the Jet GH-1340w which is handy as you can still get some parts for them at EReplacement parts.
Mine is 220 volt three phase which is beyond my household service so I took out the contactors and relays and put in a VFD.
Did you get any change gears with it? There is a set which handles metric threading.
This is single phase.That looks a lot like my Enco GH-1340a
Nice grab! Congratulations!Looking for info on a KBC GRIP-1340G lathe. Are they decent? Should I keep looking for old heavy iron while I get by with this?
I have already bought the machine, moving it tomorrow. I got the lath and a stand alone smithy mill plus several tool boxes worth of tooling, starrett tools, mitutoyo tools, rotary tables, hundreds of taps, over 1,000 drill bits, endmills, 2 5 gal bucks of HSS .... id say a solid $8-10k or more just in tooling. Snagged it all for $2,000, tooling and both machines.
My past machines were a 12” atlas and a SB 9b. I restored them both but really looking forward to a larger 220v machine.
I did the same thing.That looks a lot like my Enco GH-1340a
?? It looks like this is a typical import and it would have a gear box just below the main part of the head stock with either levers or round knobs to shift between threads and feed speeds. Give us a photo of the head stock face with all the levers & mobs. There will be a chart showing how to set the change gears & or levers to select feeds and threads. On the head stock there will be a lever for reversing the feeds and likely having or doubling the rate. Quite a bit different than a SB.Is 28tpi the only standard thread yours does?
