- Jan 10, 2019
- 1,220
Picked up the fabricated granite slab that will become the gantry. Would have been disappointed if this had been an appearance item, as they didn't stack all three pieces evenly. They sawed three sides square but for some reason left the fourth untrimmed. That side will be placed downward where it's not visible, but it was a reminder that one has to really check over anything fabricated for important requirements.
Used roller guides, rails, and ball screws have been ordered off eBay but were still expensive. As I tend to do, it's a bit over-the-top, meaning heavy duty and precise, but I don't want to spend more in the future replacing poor quality parts. Still to be purchased are servos, power supplies, and controller, but that can happen later. A whole lot of holes have to first be drilled in the granite and I haven't decided how that's going to happen: handheld drill; buy a small drill press or farm the job out to a CNC business that can drill granite. I suspect that last one could be hard to find but it's worth a try if for no other reason than to know what they'd charge. That way, if I decide to drill them myself, I can at least keep reminding myself how much I"m saving, hah.
As mentioned previously, I'm pretty much building Piotr Fox Wysocki's YouTube build, but also incorporating the upgrades covered in his "Epic CNC Upgrade" series:
. I'm doing this even though his uses and mine may differ. He's running a business and uses this as such, so it's a deductible business expense, never mind that he's getting enough publicity from his videos that vendors donate some components. Me, I'm building it just because I want to, with no immediate source of income lined up once it's finished. Still, being able to machine aluminum - extremely well - does present opportunities. Cutting wood would be completely trivial as well, so who knows!
Before that all happens though, there's still a remodel to finish - I took the summer off because of the heat. Also, a fence between us and a neighbor needs replacing, and we'll probably build it ourselves. Then there's painting the house, installing new rain gutters, and on and on. Of course, if drilling the granite is farmed out, that could happen while I'm working on the house or yard, so there's that.
