- Jan 10, 2019
- 1,220
I've been away from this forum for a few years. In that time, I built a CNC router but completely forgot that there's a subforum for such things here. As a result, the thread exists elsewhere, so over the coming days, I'll transfer it over here, where it'll be more at home. The original posts will be move here in order and without change, so what I say early-on may have changed later. The project started in mid-2022, with this first post:
As a "blue sky" project I've been thinking about this for a few years. Until recently I'd all but decided to go with a laser because it's so much cleaner and quieter compared to a router. One issue with a laser is that the length of the tube is fairly proportional to how much power you get. Knowing me, I'm not going to build something small and want something that can cut 12mm plywood. That necessitates either multiple passes, or higher power. Getting a 150-200W tube... they're roughly 1.5-2 METERS long! That's simply out of the question in a one-half a garage setup. There are fiber lasers (that have the nice feature of not needing a series of mirrors), but they're even more expensive, and emit a different frequency of light. Good for cutting metal, not so good for cutting wood. I'm not kidding myself into thinking I'm going to start cutting sheet metal, so it sort of rules those out. With both laser types somewhat off the table, I reluctantly starting thinking about a router again.
They'll do what I want, cutting wood, and if rigid enough, cutting aluminum. As mentioned, they're loud and messy, which kind of sucks. In addition to the noise is all the fine sawdust, so another noisy vacuum is needed, and I doubt that'll get it all. Being in a garage connected with the house brings with it certain consequences. Then there's zooming out and asking the hard questions: What am I going to do with this that I actually "need" one? I don't like that question because I don't have a ready-made answer all queued up. Yes, there's wood gear clocks I keep mentioning, but another hard question is "well how many of those do you plan to make?" And: "If you're only going to make one or two, just send out the files and let a pro shop do it." So, yeah, there's that.
