- Oct 7, 2020
- 2,341
Maybe it's just their stuff won't work without modification, and they don't do the mods.
Hi, did you have to machine your t-slot or did your QCTP come ready to use...?Maybe it's just their stuff won't work without modification, and they don't do the mods.
Hello... I apologize if I was at all sounding rude, I am not trying to ruffle up any feathers here or with PM.Ask John if the current lathes are any different than the PM1236T I purchased from Precision Matthews in November 2020, and if not, how am I able to install an AXA on my lathe that he says is impossible to do?
This is a solid plinth identical in height to the cross slide that I took off the lathe a couple months back. I think I have some pictures of that if necessary. This is a 1/2” tool in there, set exactly to center height and I have plenty of room above and below the tool block. There is exactly 1/2” adjustment above the tool block, so I can easily use 1/4” tools in there if I wanted to as well. This is a knockoff 250-100 toolpost, so most likely identical to the one they are selling. Someone can correct me if I am wrong, but the height of this looks ideal to me.
No not at all! You are rightfully so asking questions and I would be skeptical too if I was getting conflicting answers. I am disappointed PM is unable, or unwilling, to explain why an AXA is “impossible to fit” when that clearly isn’t the case. There could be a case such as mksj mentioned where an AXA doesn’t fit as well as a different size, but I haven’t come across that yet, and when I get home later today I am going to see if there is that situation with the 1236T.Hello... I apologize if I was at all sounding rude, I am not trying to ruffle up any feathers here or with PM.
K so I guarantee you'll find this very hilarious...I am disappointed PM is unable, or unwilling, to explain why an AXA is “impossible to fit” when that clearly isn’t the case.
