- Jun 29, 2018
- 92
I got it moved, almost moved into it's permanent location. Since I had to remove the handles, power feed, and lead screw for the table, is there anything I should do / check while it's partially apart? Clean out the old grease? Check the lead screw nut for wear? Are replacements available, or are they stupid expensive? Upgrade-able from the kind that bend to the split ones for the backlash adjustment?
Change the oil in the head?
Also, curious about getting [or un bending] the handle for the leadscrew that moves the table forward and back. It must hace taken a hit in the past, as it's bent.
