4
4GSR
Forum Guest
Register Today
The service manual I have, shows a fairly clear picture of the retainer nut p/n 1133. There's also a washer p/n 1482 that is used. I suggest using a brass or aluminum bronze washer, not 660 bronze. This will help making up and breaking out things. On mine, the end of the spindle was damaged, been hit on too many times and the threads damaged. The nut was missing as well as the draw bar, like on yours. I machined the remaining threads completely off, beveled the inside edge with a healthy bevel. Made a spacer that registered on the bevel and face of spindle, then made a brass thrust washer to ride between the bushing and the nut. Made a draw bar from a piece of drill rod, you can use just about anything you want as long as it is good straight material. Any cold rolled bar material will work.
