- Dec 7, 2018
- 653
Well, I hear ya, but here is a Starrett 18” Machinist level and it is only accurate 0.005” per foot. For about $350 give or take.A Starrett 6" level is nowhere sensitive enough to level any lathe, the grads are .005" per foot; the level used for machinery leveling and alignment is 10 times more sensitive, .0005" per foot, a #98 level is not going to do the job.
98-18 Machinists Level with Ground and Graduated Vial
The Starrett 98 Machinists Level with Ground and Graduated Vial includes a cross test vial and a single plumb vial. 450mm (18") size, without case.
www.starrett.com
So to get the 0.0005” per foot you need to spend $900.
199Z Master Precision Level
The Starrett 199 Master Precision Level provides the ability to ensure a level machine setup, which in turn increases the efficiency of modern, high speed machinery. Master Precision Level, 15" (380mm).
www.starrett.com
Seems to me for home Hobbyists the lower cost levels at 0.005” will be fine. If I was a machine shop with customers then I would want to be as level as possible.
