- Jun 12, 2018
- 724
Just ordered a Starrett 6" level.
I haven't leveled my lathe before, it's a PM1127
My plan is to use 123 blocks on the opposing ways close to the headstock, set my level, zero the bubble on the level
Then go to the tailstock end, set the 123 blocks and level on that end and lift one leg until the bubble is exactly as it is on the the headstock.
Do you guys recommed using feeler gauges to prop up one leg of the lathe? My bench does not have adjustable feet. My lathe is bolted to the workbench.
The carriage is easy to turn when it's close to the headstock, but gets harder when I move it to the middle and gets easier as I move closer to the tailstock.
