Walzfab here, Greetings, Look at the rear of the machine base on your 21-100 mill (Cast iron base, not sheet steel cabinet) You may find a model-s/n tag/plate (if it's not missing) than google " Rockwell 21-100 mill serial number date"I bought this mill from a guy closing an auto shop.
The motor has been removed by the PO and the wires disconnected. I will try to clean the wires to see if they are still marked, but as of now they are all just black.
I have all the parts for the mill except 1 for the quill feed clutch. I think it is a tapered bushing about 2 inches in diameter.
It is an R-8 quill. I can not find any evidence of a locking pin in the quill. Don't all R-8 quills have some kind of key that stops the tool holder from spinning? Can this be repaired if it is sheared?
Any guesses on the age or model?
Thanks
John
Or similar verbiage see what comes up
