Water table, machine is all setup less the water table & grid system, I have cut a few parts that were pre programmed in Mach3 and now I'm just learning Bobcad & Sheetcam
Cool, I use Bobcad and sheet cam as well. Still running a "Virgin"(never seen the internet) window XP computer. I know I'm on borrowed time with the computer, I just hope I don't need another version of BC when I upgrade.
Keep us posted on you WT build.
This is going to be a fun post to subscribe too! Flameheads rule! On the compressor- What is your minimum CFM you will need or use? I run from a 10 to a 21 (30 gal & 100 gal) The compressor will get a workout on long cuts or extra thick material. check out the YouTube vids on a Radiator cooler/ moisture removal. I have my coil set but need to have a haker/maker day with it.
You probably know of Jim Colt. he swears you do not need a air dryer? He does not and runs things that look incredibe. anyway- Now subscribed. Keep the pics coming. That is a very nice unit!
