The only obvious thing that I see that isn't correct in the general case is that 99% of the time, the QCTP should be set square with the lathe's longitudinal axis and not square with the compound slide unless the compound slide happens to be set on zero degrees or 90 degrees. About 0.99% of the remaining 1 %, it would be rotated 90 degrees CW putting the turning tool holder on the tailstock side for specialty work near the tailstock. The only case I can recall after 40 years of use is setting it to briefly to +/- 15 degrees in order to cut a 45 degree bevel using a 60 degree cutter.
Otherwise, it does look much better.
