- Jul 22, 2022
- 128
manual states to use mobile dte heavy medium oil for basically everything, what quantity i need to order in to fill everything up is not. anyone know how many gallons i need?
Fill it to mid way of the sight glass, run the machine for a few minutes, let it rest a few, add more oil to bring it back to the center, if necessary.
I just ordered the 5 gallon pail of that in ISO 46 with a 20% off coupon today and it was $83 with tax.A bit surprising the the oil volumes are not listed for your lathe. I would figure around 1.5-2 gallons if you include the heastock, gearbox and carriage. I have a similar size lathe and that is about what it takes, although I use ISO32 in the headstock and Vacuoline 1409 (ISO68) for the gearbox and carriage. My lathe ways are lubricated through a carriage pump which was the reason to use the Vacuoline 1409 which is both a gear and way oil. In the headstock I have been using the Miles hydraulic oils from Zoro, with their typical 20% off coupons and free shipping it is a lot less expensive then the Mobil products. Unlikely to see an oil product breakdown in a lathe as a hobbyist, but it should still be changed on a regular bases (annual or every other year) as moisture will accumulate over time.
Miles Lubricants 5 gal Pail, Hydraulic Oil, 68 ISO Viscosity, 20W SAE M001000703 | Zoro
Order Miles Lubricants 5 gal Pail, Hydraulic Oil, 68 ISO Viscosity, 20W SAE, M001000703 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.www.zoro.com
