It occured to me after I had shut down last night that I had given instructions for wiring a 120 motor circuit, not a 240. This is a seriously misleading mistake as one side of the 240 volts will stay hot on the machine until it is unpluged. Always~~~ The simplist solution is to locate a seperate 2 pole switch that disconnects the line cord before the connections to the reversing switch. There are other methods to solve the problem, but they cannot be done through the reversing switch.
The style of your reversing switch will not disconnect both lines of a 240 volt single phase circuit, regardless of where it came from. It is set up for a 3 phase motor and is used on single phase where one side of the line is at ground potential. England, Europe, Japan, etc. can do this on 240 volts. In the US, the 240 volts is center tapped and grounded to get 120 volts, leaving two hot legs at 120 volts to ground.
