Hi Guys,
Last weekend I picked up a Jet 1236PS for $120! It's in great condition, the spindle is tight with almost no measurable play on the dial indicator, the ways don't appear to have any damage or wear and everything works fine. It doesn't have a chuck or any back plates, but no big deal, it's a later version after they change the spindle thread to 2-1/4" x 8tpi (the earlier builds were 60mm x 8tip).
The problem is that it's missing the cross slide and everything that bolts to it... Somewhat hard to use without that...
I've contacted Jet and they don't have any parts for this lathe anymore. It appears to be the same as
No Sir. I'm looking for a nut for the leadscrew. Maybe it would be called compound leadscrew nut. Grizzly's website calls it a leadscrew nut but I didnt want to confuse it with the leadscrew nut for the cross slide. I could turn down a piece of brass at my current skill level but I'm not sure of the thread size. On Grizzly G4002 and G9249 as well as Lantaine, they call it 15mm. Would I cut the threads with a boring tool or tap? I've never worked with any kind of ACME thread. Any information on a part or manufacturing a part would be greatly appreciated. Thank you for replying to my question.Do you mean the clamping nut with the handle on the side......your measurement indicates 9/16",probably UNC thread.....in any case,just find a nut,(or a double thickness nut) and tighten it with a spanner.....Then make your own,that s what the lathe is for.
Hi, would it be possible for you to take some pics of all the labels on your 1236 JET lathe? I just finished getting mine back i good shape but all the placards/labels are faded, i would really apricate your help on this.
Hi, My name is Monty, I just finished restoring my Jet 1236 lathe, would you be willing to help me with some pictures of all the placards, I believe there are five of them, all of mine are faded. I could pay you for your trouble.
