Set the bearings up with a indicator and leave about .001 end play cold , taper rollers can't be run with zero end play they have to have some when they warm up. You may be able to get it down to .0005, bit try .001 first. I worked with the timken co. years ago on a besly double disc grinder, they thought they could run them with zero end play but after a short time they seized up.
