- Oct 30, 2019
- 225
I recently had an opportunity at an auction to pick up two Jacobs rubber flex collet chucks. After finding a great, brief Youtube video on the first few steps of disassembly as well as the attached manual, I went ahead and broke one of them down for a full clean/lube service. I went a few steps further than the author of the video, because I was keen to get the bearing race cleaned out and lubed
They both started out looking kinda like this. Everything seemed to move and work right, lock worked, etc... but the bearings were dry and I couldn't in good faith put this on the lathe and just go to work.
Disassembled
Put the parts through the ultrasonic cleaner, then the steel parts in evaporust for a few hours. Rinsed with hot water, blown dry with shop air, then hit everything with a bit of paste wax to prevent flash rusting.
Reassembled quickly and easily, the manual says a light machine oil for the ball bearings (33x 1/4" balls inserted through a small port), as well as on the threads of the nose.
Cleaned up real nice, ready for its next decade or two of service.
Before and after more or less. The second one to clean up is the dirtier one, and is the one that should fit my D1-3 spindle on the Chipmaster
The one on the left should be D1-3, but it had been screwed to an adapter plate for the previous owners' usage -- so I have some camlock studs on order for it.
Need to take some measurements and identify what spindle the clean one is meant for, and help find it a new home.
I also have a few sets of collets that appear to be complete, those cleaned up pretty easily. Ultrasonic, evaporust for a bit of surface rust, then a light oiling to help them store well.
Disassembled
