Itty bitty end mills?
I use a Harbor Freight pencil air grinder for a high speed spindle for end mills down to 0.005. Has a 1/8 collet. All you have to do is hang it off of your quill. Really tiny endmills require high speed and a really stable setup.
I don't know if you could hand crank a machine with a tiny endmill, I've never tried it. Would require a really steady hand. HSS is much more forgiving than carbide.
This has me wondering if I could rig up my Dremel somehow. That would have the speed, not sure how I could securely mount it to work with the mill though...
The problem with a Dremel is the nose bearing mount sucks. They flop around like a fish out of water. I did look at a Roto-Zip to use as a small spindle, they are a bit better than a Dremel. It would be possible to mount one of those up.
The Dremel handpiece is pretty stable, but from what I understand the drive system is prone to failure. There are some other options out there, Foredom comes to mind.
Well, talk about a co-inky-dink ... here we are talking about adding a higher speed auxiliary spindle to a milling machine, and lo and behold ... this just popped up on the local Craigslist:
OK ... might be a bit of overkill. But maybe somebody here can find a new home for it.
Disclaimer - absolutely No connection with seller and no further info about the spindle. Just saw it while browsing Craigs.
