- Feb 28, 2019
- 535
I started a thread about this style clutch a week or two ago. After a few iterations, I've ended up with what's shown here.
This photo clearly shows the ramped / teeth of the driving/driven part of the clutch. When it spins CW, the balls get pinched against the outer ring and drive it CW also. When the inner clutch stops, the outer ring continues to spin freely.
First to be absolutely clear - I didn't "invent" or come up with this on my own. I found it in a book of mechanical mechanisms (yet another thread). In my case I was looking for some sort of one way drive that I could reasonably fabricate on a small scale.
Here is the clutch assembled into the hub of a flywheel. I've got a clock work gear drive that winds up the RPMs on the flywheel until the spring runs down. At that point the flywheel is free to continue spinning.
I made the steel carrier in the first photo so I could see what was going on with the different versions and fine tune the number of balls and the ramp design. It turned out to be -REALLY- useful to keep the balls in place while inserting the clutch into the center of the flywheel.
I'm pretty impressed with how well this works as is right now. The flywheel currently just spins on the center shaft and there is quite a bit of friction - surprisingly it still continues to spin quite well after the drive stops, but it has a lot of drag that back drives the gear train. I've got a really small ball bearing that I'm going to use to mount it to the shaft that should help a lot.
You can also see little indents in the brass clutch where balls jam. With steel against brass, the brass is already losing. I'm going to try cutting steel on my little desktop CNC (another learning project). That will allow me to make the drive clutch out of steel and use the carrier as the outer race in the flywheel.
I'll post a video of the windup gear box in action when I figure it out.
-Dave
-Dave
