Hello,
I'm sure someone can help me here, I have a head scratcher...never had this issue occur before and I was unable to solve it myself.
I am trying to tap a 1/4-28 hole, .75 deep, it is a thru hole, so no bottoming out. The material is aluminum (6061) I bored a thru hole on the lathe with a #3 drill as a pilot. Selected my run of the mill, Irwin tap from the hardware store (new tap) double checking to be sure I had the 1/4-28 tap. Mounted it in my tap handle, put a few drops of cutting oil on it and with the piece still in the lathe, used a spring center to get the tap started. Seemed to be cutting fine, but about 2/3 of the way thru, it seemed to get easier.....much easier. Then it got harder again. When I backed the tap out, I had a nearly smooth hole about 2/3 of the way thru, with some nice threads in the last 3rd. What?
I thought maybe the pilot should have been a bit bigger, so tried again with a slightly larger pilot hole...same thing. I thought, "the aluminum maybe...it came from a hobby store...maybe, maybe.....
So I grabbed a piece of mild steel, bored with the #3 again...same dang thing!
I have never encountered this before...what am I missing or doing wrong?
Thanks in advance!!
John
Thanks in advance!!
John
