Today asI was cleaning the lathe after doing a project, for laughs and giggles I chucked in a test bar and stuck an indicator on the bar to see how well the head to ways alignment I did was holding up. The alignment appears to be just fine, then for whatever reasons I decided to do some checks for anything loose. When I got to the cross slide I pushed and pull and I could hear and feel a definite movement. The indicator verified the movement - 0.006.
The backlash on the cross slide happens to be 0.006 as well. The question, is the movement I noticed the backlash, just displayed/exhibited in a different way?
The video is not very clear, but if you look closely at the indicator by my left hand you can see the hand moving with push/pull. The compound is solid, I was just using the tool post as a convenience item.
View My Video
Thank you.
