I can't think of any project I would undertake that would require cutting tubular stock bigger than 4" round or square, or solid stock bigger than 2", and this Grizzly "portable" with an accessory horizontal cutting frame seems to be able to do that. And it can be detached from the frame and used as a portable. Power seems pretty good--the 1HP claim is backed up by the 12.5-amp draw at 120VAC.
Right now, I use a repurposed cheapie miter saw turned into a metal chop saw with an abrasive blade, but it sure makes hot, ugly, and messy cuts.
Yes, I've investigated fixed horizontal metal-cutting bandsaws in my area, and nothing is that cheap. People want more than that even for a used Harbor Freight cheapie, about which reviews are mixed, and which probably is less powerful than this.
I have a vertical bandsaw already that will cut aluminum but it is not designed for steel, and of course does not make a good cut-off tool in any case.
Opinions?
Rick "recognizing that this is a compromise" Denney
Combination Benchtop/Hand-Held Metal-Cutting Bandsaw - Grizzly Industrial
<h1>G8692 Portable Bandsaw with Stand</h1> <h2>Just the right size metal-cutting for most small cutoff jobs.</h2> <p>The G8692 Portable Bandsaw converts from a bench-top metal cutoff saw to a hand-held portable metal cutting bandsaw in just seconds! <p>Two blade speeds of 190 and 262 feet per...
www.grizzly.com
Opinions?
