Hi, have you considered trepaning? That is, effectively parting off along the z axis. I used to do alot of this with tool steel billets. It was fast and gave you a usable ceter slug of material for another job. Blades are available to fit standard insert parting blade holders, just make sure to get the correct radius for what you are cutting ( they have a radius range on the blade to ensure relief ) and make sure your set up is rigid and blade is indicated square.I have a custom little project I am working on. I have a 5-1/4 dia, 1 inch thick aluminum disc I am needing to bore a hole in. I have chucked it up, faced it and drilled a small center hole and started going up till I got to my largest drill bit (3/4). Now I have switched to a boring bar. I went at it for a bit and have gotten it up to about a inch right now. However I need the hole to be 2.75 inches. At the rate I am going with this boring bar, it will take all week to enlarge this hole.
So I was wondering if there is a faster way to bore a large hole on a solid piece of work, on a lathe?
I thought about trying to mark roughly where the hole would be with a marker, leaving my self some wiggle room, then take a regular carbide tipped tool bit, then start at the current center hole and basically make face cuts stopping at the mark I made and then keep doing that over and over till I reach the other side, then finish the the hole with the boring bar. Could that work? I figure I can take slightly larger cuts with a standard tool bit than I can with a boring bar, since the boring bar flexes some if you take too heavy of a cut. Would this be recommended/safe? Or is there a better way?
Nice to see something I added those years ago!If it were just one part I would just keep boring as you are doing, shouldn't take that long. If it is several parts I would look at ordering aluminum tube with 5.25 OD and 2.5 ID and finish off the inside with boring a little.
I think old timers should warn new guys not to cut all the way thru part.
the tool can break and somebody can get hurt.
Lol, sorry all, am new to forumsNice to see something I added those years ago!
