Is the MAX diameter of flycutter circumference the same as "Max. Face Milling Capacity" for a bench mill?
I like those! Two inserts and available in SEHT and APKT. Much better balanced than a regular flycutter. Might have to get one.
The "Max. face milling capacity" of my bench mill is 76mm
Does the mill have the same flycutting circumference limit ?
There are two limitations::
a) distance between the spindle and the column
b) how slow you can run the spindle
My 940 says 80mm face mill but the mill will do more and I have run a 6" fly cutter and I am building a 9" fly cutter. also note worthy, typically a face mill can and is used for hogging material (deeper cuts) while a fly cutter is used for skimming the face for finishing.
