- Apr 28, 2016
- 86
I have noticed that 6" long parallels are commonly available in widths from 1/8" - 1/2" and am wondering if this dimension is a significant parameter for any operation when using a milling vise? Thicker parallels seem attractive from the point of view of being less likely to fall over when positioning work. There is also the obvious issue of needing clearance when making a through hole near a jaw. Are there other considerations? Is there a compelling reason for a hobbyist to have parallels in multiple widths?
For example, when squaring rough stock, is parallel width significant in terms of wanting contact as close to the edges of the stock as possible? Or is it irrelevant because the primary referance surface for rough stock is the fixed jaw?
