Is lathe milling attachment worth making
Just a suggestion for those milling (as I did before the mill came along) with a slide on an angle plate: Bring the tailstock up behind as additional support, it'll make it surprisingly more rigid and give a way better surface finish!
Dave H. (the other one)
I think GoceKU that you may be reassured regarding the abilities of a lathe mounted milling head, especially on the larger lathe you have, by viewing my web pages showing a quite large stationary steam engine being made using my milling head on a Myford lathe. This can be seen at http://www.homews.co.uk/page177.html
Details for making the milling head are at http://www.homews.co.uk/page158.html which also has a link on that page to a video I made showing the milling head being used.
Harold
I need to buy couple of end mill cutters, in the pictures i've seen all are 4 flute cutters, is there a reason for this or could i use 2 flute, 6 flute or even a shell mill cutter ?
In the meanwhile i had this insert cutter head, and decided to make a shank for it, started with 45 mm peace of 4150 which had some surface rust, first i made a clean up cut than i cut down to the cutter size and then down to the 16 mm boss for the cuter, than i drilled and threaded it for M8, than i cut it off, i need to drill two 8 mm holes and install two pins to locate the cutter.
DSC_0007.JPG DSC_0009.JPG DSC_0011.JPG DSC_0012.JPG DSC_0014.JPG DSC_0015.JPG
Today i decided to chuck up a end mill that i bought recently and try milling steel in the tool holder, i was afraid of chatter, but it all went smooth, first cut was 0,3 mm, second cut was 0,5 mm and last cut was 1 mm depth, that is an 14 mm two flute end mill and run it at 400 rpm and hand feed it i like the results, this give me motivation to keep going.
My setup uses 5C collets to hold the end mill (in conjunction with a draw bar). Holding small stock in the QCTP works well. I have a milling attachment but haven't used it yet.
Roughing end mill with some 1/2" brass. Just testing out the new setup.
3/4" 4-flute end mill for milling little flats on some replica valve spindles I'm working on.
Using the QCTP was ideal for this application because I could quickly pull the tool holder and bring it to the work bench, reset the work piece in a new orientation, drop it back on the tool post and mill the next flat. I had 80 flats to machine :eek:
You should make a "thread protector" for the spindle nose, they are also used to eject the taper/collet adaptor from the spindle, drill a couple of opposite holes on the OD, and use a pin spanner to screw it off which pulls the taper adaptor out of the spindle. One came with my 19" Regal Leblond and I made one for my 9" Monarch: it is easier to remove the adaptor than using a knockout bar from the end and does no (possible) damage to the adaptor.
Nice going GoceKU !
IMHO keeping the machine running as smoothly as possible is very important. Several methods of work holding have been put forth, again I think stability is key. My keyway cutters are about .75 inches in diameter with six 1/8" wide cutting edges on them. The keyway cutters were held in the lathe chuck with the spindle driven in back-gear.
The round work piece (it was short) held in the milling attachment parallel to the ways. With the work lowered enough to provide the amount to be removed I was able to rotate the whole work holding assembly 60` then slowly cut the flats with the cross feed.
There was a recent article in the Home Shop Machinist Magazine about calculating proper sizes of round stock to get flats for typical wrench sizes.
Enjoy your machine work.
Ray
Great idea, thanks! I've been using a knockout bar to remove the adaptor but don't like doing it that way.
At the time I needed to do milling to cut a keyway I only had my 8x12 HF metal lathe. I made the milling attachment from a piece of angle iron and a cheap drill press vise. But hey, it was solid and it worked. Now that I have the HF 33686 round column mill/drill the lathe attachment sits in the bottom of my cabinet drawer.
