Thank you all for all your advices, i completely forgot that i have some loctite green bearing glue, i also forgot to mention that this is a easy to find replacement part, they are 2-30$ new. That said i decided to take a chance as i'm reusing the bearings and just do a fine knurling and use some loctite bearing glue, if it fails i'll do the bearing conversion where i'll bore the upright to accept a sealed wheel bearing and never worry about them again, this is one of the common problem spots on this vehicle.
