- Jun 12, 2014
- 5,160
When looking at the chip load for mild steel using a carbide cutter, I usually see 0.001" for a 1/4" carbide end mill. SFM range anywhere from approximately 50-250, using 200 which may be a bit on the high side if harder material, you get an RPM of 3000 with 12 IPM, if 150 then 2300 RPM with 9 IPM. I only do manual milling, but use a power feed and set the IPM off of the DRO. With steel I use 4 flute carbide and cobalt end mills usually with some cutting oil, with a full size knee mill I usually end up milling at 1/2 the rated SFM, and usually a bit lower on the RPM. You might be a bit too aggressive in your milling parameters.
