- Dec 15, 2014
- 53
Another quick tip.... Fly cutter sounds fine. And the bigger the insert radius the better. To reduce chipping, take the widest cut possible because you will minimize entrance shock as well as exit shock. Zero load at entrance full load at centerline and zero load at exit. If your cut is smaller than the cutter diameter, use conventional milling to reduce shock at entrance. This is especially successful with ceramics. If you are able, use the biggest lead angle possible and place initial impact above the bottom tangent of the insert. Use .002 chip load on a small radius insert and up to .005 with a 2 or 3 rad. Depth of cut, do not use more than 30% of the corner radius. This will allow for some chip thinning. 225 SFM to 250 SFM will do nicely for carbide, run 1,000 SFM for a AL2O3TiC ceramic. NTK HC2, Kennametal KO90 are good for starters.
Good Luck!
Gary
Good Luck!
Gary
