- Aug 6, 2015
- 4,208
Okay... just in case... I recently got a larger milling machine and lathe... Where I bought those machines they still have this Atlas MFC horizontal mill... Asking price is US$2,500.00
Knowing that I have no real specific use for any of these machines... I just want to learn and play with them... Is something like this needed? A must have? Or with what I have I should be happy and able to do anything that I want?
I guess the real question I should be asking, knowing that I have these machines:
What is another must-have machine that I should be looking to get next? As far as tools, I have David's list (Machine Tooling Get Started List January2022) that is a great guide to what I am missing on that front... I am asking if I am missing a must-have machine?
- Grizzly G0704 with CNC conversion in progress
- HF 9"x20" Lathe
- Wells-Index 847 milling machine - that I have not made a single chip with... still going over it...
- Grizzly G0709 14"x40" lathe - yeah... still going over it as well...
- CUT50 Pilot Arc 50 Amp plasma cutter
- Hobart Handler 140 MIG Welder with gas shielding
- Eastwood 200 Amp DC TIG Welder (which can't do aluminum and still have not been used)
- Couple of drill presses - one benchtop and one floor mount
- Wen 3975T 4-7/8-inch x 5-inch Metal-Cutting Benchtop Band Saw with homemade table adapter - this has been an amazing purchase. Using it a lot.
- Angle grinder
- Metal cutting chop saw
- Several bench grinders with Norton aluminum oxide wheels, 3M deburring wheel, buffing wheels, etc. I still need to make a tool grinding post for one of them...
- HF 12 Ton H-Frame Floor Shop Press
- Air compressor
