Hello everyone. I am making a component (basically a nut) out of 17-4 stainless steel rod. I would like to tap a 5/8-11 thread in the center of the rod on the lathe with index tooling. I know that I can thread it manually with a 5/8-11 tap, but I've learned the hard way that tapping 17-4 stainless is not forthe weak. I would like to avoid it and I have a bunch of nuts to make.
I have 11IR and 16IR inserts and the appropriate bars (cheap ebay stuff). 16IR inserts will not fit in the hole and 11IR will not cut a 11 tpi thread. Any thoughts on tooling I should be using for internal thread a of 5/8-11 hole?
