Hi,
I want to make a capped tube with a screw in cap out of 303 stainless. I'm not sure about the diameter at this point because I'm unsure about the threading aspect and that may change the diameter, unless I can cut any thread at any diameter (please forgive the lack of proper terminology). I'm thinking of a total length of 1 1/4" and a diameter around 1/2 - 9/16". The cap will have a turned down section at the end so I can drill a hole for a key ring. I'm hoping for a fine thread so I can get several turns of the cap to ensure a tight fit. I want the cap to have external threads so it screws into the tube leaving a seamless joint maintaining the tube diameter when finished.
Zero experience using the gears and cutting threads but I need to know how to do this for an upcoming project. I've cut threads on a lathe before in shop but then used a tap to make the matching threads in a hole. Never made both on a lathe.
I'm thinking about making the cap first, 1/4" in length, plus threads. Parting it off and then making the tube.
I figure if I make the cap first leaving enough to turn down the end for the key ring, then make the tube, I can assemble both pieces, turn down the end, and take a finishing cut across the entire length then part it off.
I know I'll have to change the gears for all the operations but that's not a big deal. (Lathe I used in shop simply had levers to set gear ratios, not a mini lathe. Need to actually change gear configurations just in case anyone reading didn't know this.)
What I need to know is this:
- Can I cut threads of any desired diameter, both internal and external or do I need to adhere to standard sizes?
- It seems to me that cutting 28 threads per inch on 1/2" diameter stock could also be cut on a 1" diameter stock so starting diameter doesn't matter, does it?
- Anything I need to know about cutting internal threads? I want to use a fine thread so I can get enough turns of the cap to ensure a tight secure fit. I realize I will need to make an internal threading tool. Buying one doesn't seem practical right now since this project is so small.
I know I'm overlooking some things but that's why I'm here.
Anyone see something(s) I'm missing and of course, answers to my questions will be much appreciated.
Michael
