Being in the automotive powertrain business, that video has been shoved at me non-stop. All I can say is a lot of complexity for no real gain. The example is for a bicycle. Scale it up for automotive use and even a Van Doorne belt starts looking good.
Isn't the torque of any transmission transferred through only one gear at a time?
Well it is only a prototype so yeah, lots of testing/proving needs to be done.
Apparently the gain could be an increase in efficiency. Also since it can start from zero rpm it could eliminate the need for a clutch or torque converter.
Not only is it a single gear, but thru an arm that doesn't look too robust even if scaled up, and more importantly to me, it relies on a one-way bearing. How long is that bearing going to last under any load heavier than a bicycle?
I don't think it relies on the one way bearing. The video said it was there because the prototype was for a bicycle and needed the one way feature to prevent the pedals from turning, while coasting.
Torque in an ICE is transmitted one crank at a time. The one way bearing aka sprag has been around for a very long time and is commonly found in automatic transmissions.
edit: From what I understood, the sprag was use in the bike transmission to allow the pedals to free wheel. It wouldn't be necessary in an automotive application and would in fact, prevent engine braking.
An interesting idea. Any concept can be scaled up to address increased power needs. Increasing power transmission efficiency by 10% is a laudable cause.
Was discussing this with a gear-head here at work.
He mentioned the Prius CVT being much like the old "three-speed hub" planetary gear system used in old bicycle rear axles. The kind where you lock one component at a time to achieve three different speeds, except instead of locking you rotate one component with a low-power motor to give the continuously variable features.
He knows a lot more about these things than me, so I guess I gotta go look up the Prius CVT now.......
