Interesting post on penetrating oils
So....has anyone here used/tried this formula? Does it mix together? I cannot get a definitive answer from the thread - yes or no.....just curious......
I guess I could just go mix up a little myself - I have both ingredients in the garage cabinet.....:thinking:
I tried it and wasn't impressed. The acetone seperates from the ATF and evaporates quickly, leaving you with ATF which on it's own isn't a very good penetrating oil.
Will have to test it but PB Blaster always seems to work best on the autos for me.
Have a great day!
Ed
Kroil is king in the gunsmith world. So much so I would be afraid to say anything against it to my gunsmith buds. :scared:. I have seen it do some amazing things though.
I think that is the point,the acetone thins down the ATF to where it will pentrate.Then in a matter of mins the acetone evaporates leaving the ATF.Like ya'll, whats the point when there is other products within an arms reach---kroll
I am assuing that we are on the subject of a bolt rusted in a steel part or something similar. Anyone ever try sulphuric acid from the hardware store? It is acid and you must think it out before applying. Think about the parts you want to separate, personal protection (eyes, skin, clothing, etc.), the physical location of the parts to be separated and how gravity will affect the application (water runs downhill type of thing), and what is near it. Also handy to keep a container of water large enough to place the part in to neutralize the acid. A large container is desirable. Also, be prepared if you spill some where you do not want it. I have used it many times and it will get rid of rust (and I have the holes in my clothing to prove it). An acid brush works well in applying. Like I stated, it all depends on the situation. When finished, the metal will be ready to rust and I have experimented with alkaline cleaners when rinsing to help neutralize the acid - Purple Power comes to mind. Is it better than just plain water ????? Makes me feel better using it as the final cleaner in the rinsing process before drying.
