- Dec 18, 2019
- 7,385
I tried out some of those vacuum bags and filament, with my home made RH meter. The meter is powered by a single 18650 battery. Putting the meter in the bag with silica gel and sealing it, but not pumping it down, you could see the RH plummet downwards from the initial room RH = 17%. The RH in the bag was below 6% within a couple of minutes.
However, when the bag is evacuated, the RH went up. It went up to 14%. Eventually, over 24 hours it declined back down to 6%. I think this is telling me that evacuating is a good idea as it is pulling moisture not just out of the air, but the filament. I think under vacuum conditions the filament is finally out-gassing the absorbed water. And the silica gel is slowly absorbing it. So simply putting your filament in dry air doesn't really pull the moisture out, you need to lower the ambient air pressure as well.
Anyways, thought it was an interesting experiment.
