Bill, Years ago a company I did service work for used a threaded insert in a lot of their ally castings for the small screws. They were made I think by Aviaquip? They were a machined insert threaded on the ID & OD. After inserting them you knocked 4 little blades vertically down the OD of the thread effectively burring the thread and peventing it from rotating. I never had one pull out. Did a quick search but didnt come up trumps yet.
And not to run the thread off track, I think they were made for softer materials, not sure if they would work in CI.
1 good reason to insert a helicoil would be that if you just drill and tap for the next size up then the existing holes in the new jaw inserts wont be big enough. And most jaw inserts are hardened.
I would be going with the helicoils. Installed and used correctly they should suffice.
With the threaded rod i would also have a go at straightening it, like others have said, nothing to lose there.
Evan, have you got a piece of scrap CI you can try one of your helicoils in for practice?
Cheers Phil
Cheers Phil
