- Mar 1, 2015
- 71
mounting the scale is not a problem, I was hoping I could find a mounting plate for reader head, my DRO did not come with plate you show mounted to casting under cross slide. it appears I will need to manufacture one myself. any measurements from that mounting plate would be helpful,My kit from PM came with a mount plate but I wanted to mount the scale with a spacer bar so I could have access to the cross slide lock. I designed a mount based on the scale spacing and the available space.
what is the thickness of the aluminum used to make mounting plate, and out side dimensions would help also.
I can figure out dilled holes location .
also locking bolt on my cross slide is allen head type, did you change your to hex head, not a problem milling space into extra aluminum bar sent with slide, I can also make thin head wrench to fit down into bolt head area. I am thinking I could drill hole for cross slide lock if it does not damage scale , will have to see what I can come up with,
