- Sep 29, 2013
- 130
Hi Bob
I installed a 3 Axis DRO on my small mill. It was a Easson ES12 with glass scales from Hong Kong. The scales they supplied were SinPo and Sino.
Two things to watch with glass scales.
They are much larger than the Electronica Magnetic scales supplied by DroPros and would be much harder to fit to the quill. I recommend you investigate Magnetic scales. Magnetic scales are also coolant proof.
Also some of my scales were supplied with an integrated Backing Plate and Cover. Much easier to fit the Backing Plate first and true up then the actual scale goes drops on. Piece of cake.
This is particularly useful when fitting to uneven surfaces such as the Y and Z axis. Not so important fitting to the X ( back of the table) which is machined.
Hope this helps
Ron
Thanks Ron. Yeah, I actually have both types of scales from DRO Pros. I have the glass scales on my small mill and the magnetic on my lathe. You are right, the magnetic scales are much smaller and I can see how they would be an easier fit on the quill. I haven't investigated the quadrature signals on the magnetic scales yet, but I think they may use RS-422 signals rather than simple A and B signals.
Do you have any pictures of the "integrated Backing Plate and Cover." I'd really like to see that. It sounds like a great idea!
Bob
