I need to get an SCLC toolholder since the tool I have now isn’t offset for facing cuts on anything larger than about 1.5”. I use an AXA size post, so will be ordering a 1/2” toolholder and it is available with insert IC sizes of 1/4 or 3/8” depending on the brand. I have a lot of 21.5x inserts for my existing turning and boring tools and would have to buy new inserts if I went with a 32.5x sized toolholder.
Does the 32.5x insert size offer much, or any advantage, over a 21.5x insert for a 2hp 1236T lathe? The smaller inserts are a bit cheaper, but not enough that it really matters in the long run. I already have a hodge podge of toolholders and inserts I bought over the years that I am working on dwindling down to only what I really need, so it would be nice if I could stick with the smaller size inserts to reduce the variety of what I have on hand, but if the larger ones have an advantage, then I would go with them.
